    May 2007
    ok i have some time-lapse software that i wanna modify to make a normal speed video.
    the following settings are available..
    "take one frame every (blank) seconds"
    "Play-back rate (images per second) = (blank)"
    thanks
  2. What do you mean by "normal speed video"? Video that plays back at a normal video frame rates like 29.97 fps? Or video that plays back with the actual real time duration?
    If you take one frame every 5 seconds and set the playback speed at 1 frame every 5 seconds (1/5th fps) an hour of captured video will play back in an hour.
    If you take one frame every 5 seconds and play back at 29.97 frames per second an hour's worth of capture will play back in 24 seconds.
    May 2007
    thats what i meant. a video that plays back at 29.97 fps. thanks for the info..
