Since I formatted my hard drive my two hard drives show up as C and D. My DVD player used to be E. It's now I, after the four generic drives E F G and H.
Everything works fine, I just wondered why this has happened
	Windows assigns the drive letters automatically, starting with the floppy drives, A and B. The 'C' is usually reserved for the boot drive. Any other hard drives usually come next. Then the optical drives. But the assigned positons, I believe, depend on how long it takes the OS to recognize the drive. Optical are slower at that.
 It really makes no difference what letters the OS assigns, though you generally want to keep the boot as 'C'. If you want your DVD drive to be 'E', you can assign that letter by using 'Control Panel>Administrative Tools>Computer Management>Storage>Disk Management'. Find your optical drive, then R click on it. You will be given the option to change the drive letter. If another device is using the letter you want, you will have to assign that drive to a higher open letter. Then 'E' will then be open and you can change your optical drive to that.
 I've had to do this a few times when all my programs were set to look to a specific drive. If you don't have any floppy drives, you can even use A and B most times.
  Location of codecsBy pooksahib in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2011, 16:29
  Location Videohelp.comBy anon_private in forum Off topicReplies: 3Last Post: 24th Oct 2010, 22:59
  DVD Lab Pro - New OS, same location of files = Subtitle generation = crashBy Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 09:56
  Invalid LocationBy Justgrant2009 in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2007, 19:48
  Encore DVD 2.0 Movie location on diskBy thesixuk in forum Authoring (DVD)Replies: 2Last Post: 7th Aug 2007, 12:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
