i am trying to encode a divx avi fast n the furious file into a vcd. i am using the vcdhelp.com method of extracting the audio with virtualdub1.48. when i load the avi file into virtualdub i get a popup saying "vbr audio stream detected" and "vbr has detected an improper vbr audio encoding in the source avi file and will rewrite the audio header with the standard cbr values during processing for better compatibility. this may introduce up to 178742 ms of skew from the audio stream. if this is unacceptable, decompress the entire audio stream to an uncompressed wav file and recompress with a constant bitrate encoder.(bitrate 157.2 +- 38.7kbps)" so when i follow the instructions of not compressing the audio with virtual dub and saving the wav i still get audio thats not in sync with the video. any ideas on what i should try?
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
looking so sync audio and video
By loldmanjenkins in forum Video ConversionReplies: 1Last Post: 11th Dec 2010, 22:07 -
audio/video out of sync
By gibsonpm in forum Video ConversionReplies: 4Last Post: 30th Jan 2010, 05:53
