Hello, I am using DVDStyler to make a DVD, and in every title I want chapters, but don't know how to do it, in video properties there is a box of "chapters", should I put the time and a comma like this: 4.21, 5.45, etc...or is there another way?. Also I want after a title end goes to next one and no into the DVD menu again.
Thanks.
Like
0, 4:21,5:43,15:00,1:10:00, etc
http://dvdstyler.sourceforge.net/docs/DVDStylerManual.pdfSetting-up chapter points
Setting up chapter points in DVDStyler is fairly simple, once you understand the basics of chapter points. However, assigning chapter points to buttons can become somewhat confusing, partially because it is done in two separate processes. The following examples use a single menu with multiple chapter points.
The program automatically provides five default chapter points for each clip that is assigned to the movie timeline. Access the defaults by: Right click on a movie clip on the timeline -> Select properties –> View “VOB Chapters” field. The default chapter points are:
0 15:00 30:00 45:00 1:00:00
The first step is to determine where you want the chapter points to fall. If your movie clip was 60 minutes long (1 hour, 00 minutes), the default chapter points would make sense. The sequence would be (refer to diagrams below):
1. Chapter one start point = 0 (00hours, 00 minutes, 00 seconds)
2. Chapter two start point = 15:00 (00 hours, 15 minutes, 00 seconds)
3. Chapter three start point = 30:00 (00 hours, 30 minutes, 00 seconds)
4. Chapter four start point = 45:00 (00 hours, 45 minutes, 00 seconds)
DVDStyler Not Creating Chapters?
By analytalica in forum Authoring (DVD)Replies: 1Last Post: 31st Mar 2012, 18:10 -
Problem with DVDStyler?
By Regor21 in forum Authoring (DVD)Replies: 1Last Post: 22nd Oct 2010, 09:57 -
Chapters in DVDStyler.
By KTV86 in forum Authoring (DVD)Replies: 0Last Post: 12th Oct 2009, 08:50 -
DVDStyler 1.6.1 beta 2 is out
By louv68 in forum Latest Video NewsReplies: 0Last Post: 27th Feb 2008, 15:01 -
Problem with DVDstyler
By zinnia48 in forum Authoring (DVD)Replies: 6Last Post: 24th Nov 2007, 08:22
