Closed Thread
    Mar 2008
    Hi, I use VOB2MPEG to convert my VOBs in the VIDEO_TS to mpegs without problem. On the first try, the mpegs have no audio. After searching around, I installed the AC3 filter, convert again and the audio is back if I play the movie from the beginning. However, if I fast forward to the mpeg in WMP11 using the slide bar, the audio becomes static. I know this question was asked before, but I couldn't find the answer. Do I need to run asfbin to reindex or am I on the wrong track completely? Any info would be greatly appreciated
    Thanks,
    R
    Does it work if you play with a better player like vlc?
    And one post is enough. Continue in
    https://forum.videohelp.com/topic252033-180.html#1840828
