Been trying to get this to work for a week. Using Handbrake to rip from DVD to m4v. Selecting AC3 gives me video but no sound. I have my computer hooked up to my receiver via Toslink optical cable.
The Windows setting window for my SPDIF looks like this:
When I test 48KHz, it doesn't work. When I play a DVD, it does show surround sound. Isn't that a contradiction, if SPDIF runs at 48KHz?
Anyways, I switched over to AAC to test whether 44.1 KHz would work (since I can't change sample rate of AC3 in Handbrake). Ripped the first chapter of the DVD with these settings:
I get surround sound (or at least, the Dolby Digital indicator lights up on my receiver). I then change only the sample rate to 48KHz. When I play that file, I only get 2-channel sound and it's a bit quieter.
So what the heck is going on? I am really stumped.
Results 1 to 15 of 15
Jeremy Hodgkins
MP4 containers don't permit AC3 audio, so that's probably why that isn't working.
For every five people that tell me that, I hear five others that have it working. But anyways, I have the same problem with avi's. So it's not limited to format for me.
Greets,
Why not try the MKV container? It fully supports H264 and AC3. Says you are running Vista, give AutoMKV a try if you have not already. I use it and love it.
Believe I may be doing the same as yourself in playing my vids over a tv and home sound system via computer. Except that I am using a SB Audigy 2 ZS and a digi coax via SPDIF.
Unless your receiver can specifically decode AAC like it can DD you will not get the full 5.1+ / Surround / Pro Logic / etc. I went through almost the exact same things you are going through about a month ago. What you are probably hearing is the PCM audio and not DD. Nero Digital AAC is not the same as Dolby Digital.
Soopafresh is correct in that MP4 containers do not officially support AC3. Don't believe us? Look up the formal specs - I did
. That is the main reason I went to MKV instead. It is also a much more versitile container than the popular MP4. Why MP4 chose to support AAC and not AC3 as well is beyond me. Considering most every decent home sound systems already have a DD decoder built in. As well as the fact that every commercial DVD and HiDef / BR disc on the planet comes with AC3 and not AAC.
Please steer clear of H264 in AVI containers. You are only asking for trouble there. It is an old container not designed for H264. If you wish to use modern codecs it is wise to use modern containers that will properly support them. Good luck on your project.
Cheers,
Rick -
RickA,
OK. Finally had time to try AutoMKV. Program worked fine, took some time, but oh well.
Great picture. BUT! Audio is still 2-channel and quieter.
So this is now the third format I've tried (M4V/MP4, AVI, MKV) and the only thing that has gotten surround sound is 44.1 KHz AAC. I guess the only thing left to try is somehow turn 48KHz AC3 into 44.1KHz AC3 and see what happens.
Seriously, this is driving me crazy!!! -
Why don't you just rip the 5.1 AC3 audio from the DVD and mux it into the .mkv container (with mkvmergegui)?
Isn't that the goal - keeping 6 channel audio?
If you're set on converting it to 5.1 AAC for whatever reason, use Besweet/Belight or MeGUI's audio portion (based on BeHappy). All need to be configured properly to work (with neroaacenc.exe) -
Glad AutoMKV worked part way for you. Most odd still about your continued audio problem. I just use keep original audio setting. Seem to remember having probs when I was trying MeGUI and attempting to reduce the size of the audio to a lower bitrate.
I do remember the audio coming out faint and just two channels when I was trying AAC. My Onkyo only handles DD and it was showing that as PCM input.
What about trying a different video player. I like KMPlayer, it has audio settings in it and also has one for SPDIF out. Maybe something in your player is messing with your audio signal out. If you are running ffdshow check your audio settings to see that the mixer is not set to 2 channel out or something. Think I set mine to same in same out.
Try MediaInfo on your mkv file to verify your audio is correct. Will try to think of some more ideas later. Good luck.
Cheers,
Rick -
Well, here goes a not-so-stupid suggestion:
How about unchecking "µ§oft WMA Pro" in the SPDIF applet and
see if that makes a difference
Greets,
I just thought of something that may help. Do you have the program AC3Filter installed? If not I suggest you install it. If so I suggest you double check it's settings. Make sure it says SPDIF out, source same as input, blah blah you know the drill by now. I just did a clean re-install on my HTPC system and could not get AC3 DD digi out properly until I installed AC3Filter. Good luck.
Cheers,
Rick
Sent you a PM too just in case you are no longer following the thread.Rene: Could you not just wound him a little bit?
Hans: Well now, with a 25 pound shell that is not easy.
'Allo 'Allo
AAC codec not working on PC ffdshow
By jack616 in forum AudioReplies: 5Last Post: 14th Oct 2011, 00:35 -
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 17:15 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
My MKV file already has AAC audio so the conversion tools arent working
By animlchin in forum Video ConversionReplies: 3Last Post: 19th Dec 2009, 18:58 -
Convert .m4v (H.264+AAC) to XviD
By mattr in forum MacReplies: 3Last Post: 20th Sep 2008, 11:25
