http://www.bestbuy.com/site/olspage.jsp?skuId=8668998&type=product&id=1196470791061
Would I be able to easily import video taken from this camcorder into editing programs such as Adobe Premiere Elements without needing conversion programs? Does anyone know in what format this camcorder records?
I'm thinking of buying this camcorder if it is easy to import into editing programs, because my current camcorder records onto DVDs and cannot be edited without tedious converting.
Thanks.
Results 1 to 12 of 12
If those are DV cameras, then yes, it will work easy and well in Adobe Premiere Elements. Those appear to be DV cameras.
Panasonic is better than Sony. But Canon will be better than Panasonic.
Any reason you want a hard drive one? I'd suggest DV tapes, personally.Want my help? Ask here! (not via PM!)
I was thinking HDD because I liked the idea of no media to buy. Is DV Tape better? Thanks for the help.
much...
you'll have to offload and backup somewhere along the way or you'll lose all your footage
cheap DVD discs and even HDD's are prone to failure (I had a HDD fail last year...my 3 year warranty covered it)
this way, you can just spit your final production(s) back to tape for storage
the tapes just sit there on your shelf
although the research shows the typical consumer prefers a no-media HDD arrangement, most here at VH support the tried and true miniDV tape method
yes they cost $3 per hour but you'll always have your footage regardless of what happens...
the only cam I've had trubble with is a Canon...but at least it has a LANC -
PLEASE change the topic subject so it describes it better. Just click on the edit-button on the first post.
Do you know of any good ones that use USB? All the ones that I looked at online require 1394.Originally Posted by zoobie
DV requires IEEE1394 (aka FireWire). USB will not work.
I mentioned that in a thread once but people corrected me in saying some newer cam's now use USB 2 for transfer. Ive never seen one but was said on this site.Originally Posted by lordsmurf
Only for a few unnamed cams. Assume USB is not supported unless the camcorder spec states otherwise. There is a DirectShow proposed spec for DV transfer over USB but few manufacturers follow it.Originally Posted by Rudyard
The only one I've seen (consumer level) is a Panasonic model that required a driver from the enclosed CD.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I suspect that is the same model I have seen. The school I work with purchased a couple last year. If you don't use the driver then you get the usual VCD resolution WMV type transfer. Given that firewire is supposedly being phased out in favour of USB2, I am surprised it isn't being adopted more widely.
Read my blog here.
No sound playback on copied files from HDD Camcorder
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th Nov 2012, 08:36 -
what software for sony hdd camcorder
By ballboy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th Dec 2008, 15:26 -
HDD VS Flash VS miniDV camcorder. Which is better?
By vid83 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Dec 2008, 10:11 -
Which is good HDD camcorder or DV camcorder?
By tapal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Sep 2008, 04:09 -
Corrupt HDD Camcorder recordings ? Need content, ideas appreciated
By PushPull in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 11th Dec 2007, 03:07
