    Apr 2008
    alright im a runnig a duo core processor 1.8ghz conroe
    1 gig of ddr2 and micro atx mobo
    ata hardrive
    has pci express x16 slot
    my power suppy is 300 watts max i believe
    and it has 20 pin plug in and my mobo supports 24 pin
    so i have a nvidia8400 gs pci express x 16 256 meg msi power house [ lawl]
    wondering if i have all the stuff to run tha bad boy
    Feb 2004
    Australia
    Welcome hairysac
    Could you supply the motherboards make and model
    From my manual, it went on about something to do with 2x12 which is 24pin (20/4), and something else about 2x10, which isnt usable
    Most new power supplies I use have 20/4 pin, the extra 4pin can be removed if not used to suit older systems, but the new boards use this
    In your case, you need to get a new psu which supports 2x12 pin
    You also need to go up in watts, nothing here less than 500watts.
    Apr 2008
    The system is running right now lol with a 300 watt power supply and also can play some decent games with the 945g integrated card. i plugged in my gfx card and it was hot but didnt turn on. Also in bios it has an option to switch to pci express but i didnt in fear i couldnt switch bac to my integrated. MY CURRENT PSU HAS 20 pins and my mobo is 24 but it still works. Might have been something to do wit me moving the mobo over to the right. weird SO YOUR SAYING I SHOULD JUST GET A 500 WATT PSU WITH 2x12 and make it ez?
    Apr 2008
    ya my curren psu is 2x10 runs fine at 36 C and air fans
    Apr 2008
    oh and hi bjs...=p
