Hello. I took some video from a computer which captures footage from 6 different security cameras. I took it straight from the directory of where the program saved the footage. The files are in .264 extension format. They played on the security computer in something called TCVPlayer I think. But I cant seem to get the files to play on my home computer at all. I tried multiple video conversion programs but none of them worked for me. Thanks in advance for any help you can provide me with.
It sounds like it is a raw h.264 video stream.
You probably need to put it into a container in order to view it.
Use mkvmergegui to put it into a .mkv container
For viewing on PC, you need to have ffdshow and haali media splitter installed and view it with media player classic, or you should be able to view it with vlc media player (without installing the other 2)
Cheers -
I used mkvmergeGUI and it only recongized one file. I muxed it and then the new file showed as a vlc file but when I open it there is no video.
Try muxing it to MP4 with Yamb http://yamb.unite-video.com/YambInstaller-2.0.0.8.exe
security footage is most likely using a custom modified encoder and/or password locked. try using a copy of the tcvplayer from work on the home computer. is it a honeywell system?
Extracting/editing security footage
By lisabee35 in forum Video ConversionReplies: 9Last Post: 15th Jul 2013, 12:03 -
Streaming live h.264 video from WiFi camera directly to iPhone.
By mpopovi in forum Video Streaming DownloadingReplies: 4Last Post: 2nd Jan 2012, 20:25 -
Security Camera video footage software..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2010, 04:38 -
Security Time Lapse Footage to DivX/Xvid
By NightFire in forum Video ConversionReplies: 4Last Post: 2nd Feb 2010, 23:51 -
Here's a Doozie: Security Camera footage.
By RiverOtter in forum Capturing and VCRReplies: 25Last Post: 10th Dec 2007, 16:40
