    Apr 2008
    Youtube now lets you view video clips at high quality (if available) - below the video screen, click on "watch in hq" to see it in hq. But in order for a clip to be viewable at HQ, it has to be in 4:3 aspect ratio. If a clip is widescreen, it has to be letterboxed (black bars on top and bottom). Can someone suggest a tool that letterboxes a widescreen clip? AutoGK doesn't do it. Even if I use a letterboxed clip for the input, AutoGK still UNletterboxes it (removes the black bars).
    And of course, if anyone has figured out a way to upload widescreen clip in 16:9 AR (without black bars) to youtube and make it viewable in HQ so I don't have to add the black bars, let me know. Yes, I know that adding &fmt=18 to the URL will show the clip in HQ, but that's not convenient. I want the "watch in HQ" link below the video screen.
    For example, this is a clip with the link "watch in hq": http://www.youtube.com/watch?v=y1TURJ7QQd0. The original clip is letterboxed (I uploaded this clip myself).
    This is a clip without the "watch in hq" link after a non-letterboxed file was uploaded: http://www.youtube.com/watch?v=WjqGvtWlrDQ. It can only be seen in HQ by adding &fmt=18 to the URL: http://www.youtube.com/watch?v=WjqGvtWlrDQ&fmt=18.
  2. Even if I use a letterboxed clip for the input, AutoGK still UNletterboxes it (removes the black bars).
    I'm not sure what kind of a clip you're referring to, but you can disable the AutoGK autocrop function in the Hidden Options (CTRL-F9):
    To completely disable auto crop you can set threshold to 0.
    http://www.autogk.me.uk/modules.php?name=TutorialEN#6
  3. What video format?
  4. The source is mpeg. Any suggestion for letterboxing a widescreen clip?
  5. The AddBorders command in AviSynth:
    http://avisynth.org/mediawiki/AddBorders
    You can do the same thing in VDub(Mod) with the Resize Filter and the "Expand Frame And Letterbox Image" box checked.
  6. Member ricardouk's Avatar
    Mar 2005
    Portugal
    @cwy - Welcome to Videohelp
    search the forums.
    https://forum.videohelp.com/topic336882-270.html#1810201
    I love it when a plan comes together!
