I currently have an Nvidia 8600GT on my Q6600 system. I want to add a 2nd video card so that I can simultaneously output both an HDTV and s-video/composite signal. Should I stay with Nvidia or get a cheap ATI card? Any suggestions would be greatly appreciated. Thanks in advance.
wwaag
	Any card that meets your output requirements will work. For best results, I would stick with a card from the same chip maker. But it shouldn't be an issue either way. Google is your Friend
	You shouldn't need a second card unless you're running more than 2 displays. Are you running something else in addition to the HDTV and s-video devices? FB-DIMM are the real cause of global warming
  Suggestions On Buying Cap CardBy x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 03:14
  TV/VHS tape Capture card suggestions for my pc?By drwho in forum Capturing and VCRReplies: 5Last Post: 27th Sep 2008, 20:49
  Capture Card Suggestions?By duderdude2 in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2008, 01:42
  Suggestions where to get Dual monitor wallapaper?By Denvers Dawgs in forum Off topicReplies: 7Last Post: 16th Mar 2008, 23:29
  Looking for Dual Video Card - Help!!By GT Music in forum Capturing and VCRReplies: 3Last Post: 20th Dec 2007, 15:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
