Is there such a thing as an app that will create an FLV but using an .mp3 that I make?
Or on the other hand, something that creates flv files that gives you a lot of control over the parameters of the .mp3 as say CDex?
The reason it's an issue is that I find with Any Video Converter, it seems to have issues with certain source .wav files. Some it does okay with, some it doesn't.
Thanks for all input
I've looked at various sites for ffmpeg but it's not clear to me how you install and use it. The download I see gives me a file called ffmpeg.rev12665.7z ffmpeg-checkout-snapshot.tar.bz2 FFmpeg-svn-12810.7zOriginally Posted by 45tripp
I see there a thing called Avanti that's supposed to give you a GUI for it but again there's no .exe installation file, there's a file called avanti-024-package.7z
What am I supposed to do with these files?
Thanks -
well you've found the right gui.
they're compressed,
use 7zip to extract:
http://www.7-zip.org/download.html
yes you have to put ffmpeg in the ffmpeg directory of avanti's
you might want to try this ffmpeg build:
http://arrozcru.no-ip.org/ffmpeg_builds/
tripp
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 14:53 -
[REQ] Tool to create a video with photos / mp3
By qbecerra in forum Newbie / General discussionsReplies: 13Last Post: 27th Jan 2009, 15:28 -
What's the best FLV converter + best method to create FLV's from pure video
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 20:23 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 23:11 -
looking for program that create flv video for youtube from mp3,image,..
By method in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 04:56
