Your first mistake is using codec packs. Secondly, many users seem to be having issues with WMP 11 on XP.
I would try uninstalling any codec packs through add remove programs. Then use a program such as codecsniper to verify your remaining codecs. You can then download and install the microsoft codec updates.Google is your Friend
Lagarith won't play in MPC or WMP
By mst in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2012, 19:29 -
MPC with K-lite codec pack won't play ISO movies in Windows 7
By Monsoon in forum Newbie / General discussionsReplies: 9Last Post: 5th Dec 2010, 22:28 -
WMP/WMC won't play Subtitled MKV's, MPC will?
By Rantlers in forum Blu-ray RippingReplies: 1Last Post: 28th Apr 2010, 06:54 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 22:41 -
WMP/MPC won't play any mpeg video
By hhhgamewmx7 in forum Software PlayingReplies: 3Last Post: 20th Feb 2008, 11:36
