hello guys ,sorry if this has been asked before.
THE PROBLEM I HAVE IS,
when i convert an AVI file to dvd using dvd convertX then burn using their burner,
on playback i get a motion problem.
on the camera panning slowly,i get a stuttering like a judder on the picture.when its at the AVI playback stage on the pc theres no stutter,its clearly when it gets to dvd this happens?
i read somewhere about frames per second like pal 24 frames per second and ntsc 30,etc
can anyone help me on this problem ???
is there something im doing wrong ?is there a program solution you can get?
im so close having good quality dvd burns,its driving me mad.
im using sony dvd-R,4.7GB 16xcompatible discs i burn at slow rates.
please please guys can you help me.
great site
thanks very much
G
Results 1 to 11 of 11
What is the source avi frame rate? Identify it using gspot or mediainfo (You can post a screenshot from gspot or mediainfo).
Are you converting to NTSC in ConvertXtoDVD? -
big thank u for replying ,baldrick.
im a total thicko on this subject,so im not sure what you first part mean't??
FRAME RATE is were i think im going wrong?but not sure what to do??
HOW do i check avi frame rate??AH i see do i download GSPOT and this helps???
it plays fine on pc player but its when i have the final dvd played back on a standalone dvd player(also tried it on three players with same effect.
CONVERTING
second part im using convertX and its set to auto for pal or ntsc,i had it set to uk pal previously,then thought i was safe going auto.
sorry for being a pest
thanks
G -
HI BALDRICK or anyone.
regards to earlier post from BALDRICK
ive downloaded GSPOT and put my avi file in to program
and its saying
pic/s 23.976 frames 23.976 fields blank
now can anyone help here?
id would now normally get my AVI file and use CONVERTX 2dvd then burn too DVD PAL disc.
my settings in convertX is set too auto NTSC/PAL uk.
is there anything here thats causing the slow panning too judder????????
PLEASE PLEASE GUYS CAN YOU ALL HELP!!!
THANK YOU SOOO MUCH
goldenbhoy -
The framerate you posted above is PAL, which should be fine since your TV system is PAL. The only way that it may be causing a problem, is if ConvertX2DVD is converting it to NTSC. If your output DVD's are PAL, then it is working correctly. Aside from that, it is likely just a poor quality avi file. Are you testing the files on the computer is full screen? Many video quality issues become more apparent when playing back on TV. The bigger the TV, the more noticable any quality issues become.
If you do this often, you may want to consider getting a DVD player with Divx support. Then you can simply burn your files straight to CD/DVD as data and play them back. It will save conversion time, use less media, and preserve video quality.Google is your Friend -
Sounds like a field order problem to me. If so it's fixable with restream. But then you would have to reauthor a new dvd manually. If you don't want to go that route then I would suggest downloading FAVC and using that (with HCenc for the encoder) to convert your avi and author to a new dvd.Originally Posted by goldenbhoyDonadagohvi (Cherokee for "Until we meet again")
THANK YOU SOOOO MUCH FREEBIRD AND KRISPY KRITTER.
Krispy your spot on i have a divx sony dvd rec and ive tried it using that media and its perfect.however my problem still there, as i need to be able to transport media to other rooms in the house ,that have their dvd players.
your right krispy it works on my pal tv and player so i guess convertX is at least converting to right country.
i feel im so close to perfection its frustrating and me being a complete novice too.
Freebird thanks a million
you say it can be sorted? using the FAVC ,with HCenc for the encoder?????
couple of Qs? is this software free? and more important idiot proof,lol (me)
would this sort the prob?
anymore help would be really welcome
once again thank you guys
Goldenbhoy -
Yes it is free. Just download favc and it will include hcenc in it's installation. If you click the word favc on this page you will get a download page and about halfway down links for guides. Only requirements are avisynth (also free) and microsoft.net (once again free).Originally Posted by goldenbhoyDonadagohvi (Cherokee for "Until we meet again")
thank you Freebird i'll look into all that and see what happens.
i'll update when ive done all that.
thank you freebird for being so kind and helpful ,
this is a great site for us novices.
I for one would be lost without the help of all you guys.
i'll keep it posted on the results.
many thanks
G -
No problem. All I ask is that when you have successfully conquered your problem that you stick around. Don't disappear until you have a new problem. Read some posts every day and someday you will be able to help someone else by answering their post.
By the way. Welcome to the forums.Donadagohvi (Cherokee for "Until we meet again") -
THANK YOU very much freebird.
this is a fantastic site .
its great for us novices and a site that has guys like yourself who take time out to reply and try and help us which is FANTASTIC.
I hope i can add something to the site
and i will be for sure ,be hanging about.
thanks guys
still trying too work out this snag,lol
i'll keep u guys posted.
thanks
Goldenbhoy
MPC: mp4 playback stutter
By leghorn in forum Software PlayingReplies: 5Last Post: 21st Oct 2013, 23:28 -
Why DVD playback is jerky when panning?
By videdit in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Nov 2010, 13:10 -
Newbie question on video stutter . . .
By wyldberi in forum Newbie / General discussionsReplies: 12Last Post: 3rd Feb 2009, 18:14 -
FLV playback stutter
By calthorpe in forum ffmpegX general discussionReplies: 6Last Post: 31st Oct 2008, 12:48 -
Choppy/Stutter playback on some Xvids
By gidxg03 in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 14:32
