    Apr 2008
    I'm trying to convert a .wmv file to mpeg on a Mac. using ffmpegx. After selecting the file and the target format, I get a message:
    where is progress.app?
    Try as I might, I can't locate this. What is it and where does it live?
    Any suggestions?
    Adam
    USA
    Since you seem to be using a Mac and mention ffmpegX, you would probably get more answers in our Mac Forum. Moving You.
    And welcome to our forums.
    Apr 2005
    Blacksburg, VA USA
    Have you installed the needed support files? According to the docs:
    If you are installing ffmpegX for the first time, then you must also
    install the mencoder and mplayer binaries and the mpeg2enc binary.
    Al Bloom
    Dec 2007
    Netherlands
    You need to direct it to itself (ffmpegX) in your Applications folder.
