Hi,
I just tried to burn my first VCD and had a problem, it said I
didn't have enough memory. I am using Nero 5.5.5.1 and a Ricoh MP7080A
OT is Win98se and 256 ram, I don't have any problems burning other
stuff like mp3's and CD's. The file in question was only 9Mb and was already on my HD. Any idea's would be welcome.
Thanks,
Chris
Excuse me asking this...but you are burning a VCD with 9mb????
You do realize that a VCD can go up to 80mins(800mb)on a 700mb disk. -
I am only burning a 9 Mb file as a a test burn, not much point in trying to burn a big file yet until I can work out the problem with the 'Not Enough Memory' error message I keep getting.
Chris -
while I ponder the possibilities, what are your virtual memory settings?
Also Try a newer release of nero. I think the newest is 5.5.6.4 or 5.5.6.7
something like that. I loose track after awhile. LOL. -
I have at present 'Let Windows manage my virtual memory settings (recomended) box ticked.
Chris -
Same thing happened to me all day yesteday until I upgraded to the 5.5.4 version of Nero. Now I am not having that problem any more, just some new ones playing my VCD on my Yamaha DVD.
Just upgrade and your problem should go away. -
Hi,
After upgrading to Nero 5.5.7.2 the problems seem to be fixed so thanks for the input people.
Chris
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
