Hey Y'all, I got a question. I am trying to burn anything (have tried slideshows & movies) using both Nero & PhotoDVD proggies and have ACE Pro Codecs installed. Everytime I burn a slideshow or movie, the finished product comes out with skips throughout or actual stops in both audio & visual. I have downloaded more codecs, all microsoft updates, and have tried to burn with nothing else running on the computer. Does anyone else have any suggestions??!? Thanks in advance,
Shell
Do not use Nero
Do use Imgburn
Do not use cheap, crappy media
Do use Verbatim or TY media
Do not install codec packs, ever
Do run a speed test on the disc after burning - Nero CD/DVD Speed or DVD Info Pro can do this
Do use a decent software player - MPC/VLC are good choicesRead my blog here.
I will try Imgburn & DVD Info Pro asap... Never had thought of the media.. thought all was the same... and I have VLC so good to go there... Thanks much & hopefully, I won't have to load anymore problems here!
Shell -
Poor quality DVD media is one of the most common causes of skipping on a burned DVD. And the easiest one to change just by using better quality DVD media.
Hi, I certainly agree with you. Your advice is really very helpful for us.
Thanks a lot!I'M a SPAMMER
DVDs skipping and freezing after burning
By rogue_edit in forum Authoring (DVD)Replies: 4Last Post: 25th Mar 2010, 14:49 -
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 16:37 -
How to burn DVD that plays all chapters without stopping?
By billdz in forum Authoring (DVD)Replies: 28Last Post: 2nd Nov 2009, 06:53 -
Long time burning and skipping problems
By championjosh in forum DVD & Blu-ray WritersReplies: 8Last Post: 16th Feb 2008, 02:11 -
Problem with recorder? Skipping only when recording on DVD
By fastheart in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2007, 11:26
