So I am a little behind by the looks of things but I found out about EVR and DXVA today and have a few questions. (if your able to even answer one, I would appreciate it)
I notice first that playback has no lag at all, better than my experience with VMR9 and haali.. even when a avc(h264) video would jump to 100% and maybe lag a second under the old setups... EVR had no issue
My question is, how do you set it up correctly? I found a link to EVR for Xp but am rather confused why all my codec and video's are refered to a dll in my windows folder.
Secondly, what is EVR Custom? how do I adjust this?
Lastly I have a video that will not play unless under the regular MPC, (EVR support is under the domm9 build of MPC)
and here is a file of similar caliber that does work under EVR, however does not work under Haali via regular MPC, only VMR9Format : Matroska
File size : 251 MiB
PlayTime : 23mn 35s
Bit rate : 1485 Kbps
Encoded date : UTC 2008-04-16 05:37:10
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video #0
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec profile : High@L5.1
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 5
PlayTime : 23mn 33s
Nominal bit rate : 1354 Kbps
Width : 1280 pixels
Height : 720 pixels
Display Aspect ratio : 16/9
Frame rate : 29.970 fps
Chroma : 4:2:0
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.049
Writing library : x264 - core 58
Encoding settings : cabac=1 / ref=5 / deblock=1:3:3 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1354 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language : Japanese
Audio #0
Codec : AAC LC
Codec/Family : AAC
Codec/Info : AAC Low Complexity
PlayTime : 23mn 35s
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Language : Japanese
Thanks for your time and help.Format : Matroska
File size : 233 MiB
PlayTime : 23mn 59s
Bit rate : 1358 Kbps
Encoded date : UTC 2008-04-20 19:30:41
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
Cover : Yes / Yes / Yes
Video #0
Codec : AVC
Codec/Family : AVC
PlayTime : 23mn 58s
Nominal bit rate : 1164 Kbps
Width : 1280 pixels
Height : 720 pixels
Frame rate : 23.976 fps
Chroma : 4:2:0
Bits/(Pixel*Frame) : 0.053
Writing library : x264 - core 59 r821M 44361e9
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1164 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Language : Japanese
Audio #0
Codec : AAC LC
Codec/Family : AAC
PlayTime : 23mn 59s
Sampling rate : 48.0 KHz
Title : 2.0 LC-AAC
Language : Japanese
Results 1 to 1 of 1
Seedin and encoding... Healthy pc life :)
Standard definition videos (AVI) stutters while using EVR modes
By vieekk in forum Software PlayingReplies: 5Last Post: 24th Aug 2011, 11:54 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
mpc-hc and wrong EVR colorspace output
By wewt in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2009, 12:24 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 21:41 -
EVR on XP SP3 with MPC-HC
By THX-UltraII in forum Newbie / General discussionsReplies: 0Last Post: 10th Sep 2008, 06:30
