Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 12 of 12
  1. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    Hello everyone,
    I have over 200 DVDs (4.7 gigs) that I dont have time to convert to divx.
    How many 4.7 Gig DVDs may fit into 500 gig HDD?
    Thank you.
    When it sounds too good to be true, it usually is!!
  2. Okaaay
    I say nobody should answer this question and let the OP figure it out for himself?
  3. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    Thanks for your reply.
    I was trying to figure it mathematically, but did not know how to.
    I know that a 500 gig HDD has less than that.
    Any other (decent) replies will be appreciated.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Round up. Change 4.7 to 5. Then divide 500 by 5.
    That'll add a tiny margin, sure. If you're worried about running into the limit, remove at least one or two discs (5-10GB, in this case), and keep that as free space, just to be safe. It's probably better to not fill the drive to the limit, anyway.
  5. Disgustipated TooLFooL's Avatar
    Feb 2004
    Opium Den
    rt click the drive and select 'properties see the actual size (in bytes), do the same for the file, and you have your more exact math.
    I am just a worthless liar,
    I am just an imbecil
  6. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    @ TooLFooL and Ai Haibara.
    Thanks.
    Sep 2007
    I always find the answer is, "Not enough."
  8. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    I'm guessing that 500GB drive will show up on the computer as about a 470GB or so. Easy to divide that by the 4.7GB DVD size and that would give you about 100 DVDs. Actually burned DVD-5 DVDs are about 4.37GB maximum. And some may be smaller. So I would estimate 100 to 120 DVDs would fit.
    The confusion in the actual size of a hard drive is the way it's measured. One gigabyte is actually 1024 MB, not 1000MB or 1GB. DVDs have the same problem. 4.37GB is a more correct number for burned DVD-5s as it uses the proper 1024MB sizes.
    More info on DVDs can be found to the upper left on this page in 'WHAT IS' DVD.
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    In short: The capacity of a "500 GB" HDD and a "4.7 GB" DVD is calculated in the same f*cked up, marketing department way, so it's safe to say that you'll be able to fit 500/4.7=106.38 DVDs on the HDD.
    /Mats
  10. AGAINST IDLE SIT nwo's Avatar
    Jan 2004
    Stadium Of Light
    465GB (500BG)
    X
    4.3GB (4.7GB)
    108.13953488372093023255813953488
  11. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    And what are the odds that every DVD is completely full? So this is all guesstimates anyway. Not to mention that the HDD will become full way too fast and you will end up finding the time to perform the conversions for storage anyway. : )
    Google is your Friend
  12. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    Thanks guys
