I have a cap of a sporting event that was encoded using the wmv codec (.asf). The cap is about 2 hours long and the original file's audio is completely fine throughout the entire movie. Problem is, the cap contains the commercials which I wanted to remove. I used VirtualDub 1.7.8 and the wmv plugin. The movie opens fine, I get no warning messages, everything loads ok. I did the editing using direct stream copy for video and source audio/direct stream copy for the audio. The problem is, when I output it to AVI after the editing, the audio goes out of sync and it gets worse and worse as the video keeps playing. I'm not really a video editing master so I'm not sure if I did anything wrong. The whole thing seems pretty straight forward to me. Not sure why virtualdub screws up the sync during such a simple, straight forward procedure. Any help would be much appreciated.
Try latest 1.8.0 experimental (if it supports the wmv plugin ).
You could also try asfbin or Cut Assistant to cut the wmv without reconverting,
Virtualdub avi capture audio sync issues
By buckethead in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2011, 14:34 -
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Cutting a flv in Virtualdub - audio synch problems
By Faufiffon in forum Video ConversionReplies: 3Last Post: 1st Sep 2011, 14:49 -
Audio sync issues
By andy99 in forum EditingReplies: 7Last Post: 16th Sep 2008, 22:47 -
Audio Sync Issues
By Pinata in forum DVD RippingReplies: 2Last Post: 28th Jan 2008, 08:38
