Hi, I want to add English subtitles to a french film using convertxtodvd, but I have no idea how to do it? Can anyone help?
Thanks.
PEACE!!!
Do you have the english subtitles and if so in what format?
Or are you going to make the english subs yourself?
You basicly just load your video source and the subtitle file(like srt) and convert and burn. -
Hi, thanks for the quick response. The english subtitles are in rar files. I'll try to extract them and add them to the video source.
Thanks for your help!
PEACE!!! -
Do note that if your subtitles and the film are not both PAL or both NTSC that the subs won't match when you add them and they will be horribly out of sync. In theory it is possible to convert the timings for subs from PAL to NTSC or vice-versa using (I think) Subtitle Workshop, but the one time I tried to do it, it definitely did not work for my movie. I just gave up as it wasn't worth the time it was going to take to have to fix it by hand. Good luck.
mp4box and non-English subtitle
By ngngokkiu in forum SubtitleReplies: 1Last Post: 10th Mar 2012, 05:37 -
Subtitle Edit question about OCR using a french dictionary
By jesant100 in forum SubtitleReplies: 1Last Post: 9th Jul 2011, 13:25 -
Adding English Subtitles to Japenese Videos
By Jacko00 in forum SubtitleReplies: 5Last Post: 27th Mar 2010, 14:06 -
French subtitle problem
By atyamamoto in forum ffmpegX general discussionReplies: 7Last Post: 15th May 2009, 13:31 -
converting a subtitle to english?
By php111 in forum Newbie / General discussionsReplies: 10Last Post: 14th Aug 2007, 08:20
