I have a ENCORE ENLTV-FM TV Tuner & Capture Card w/FM PCI Interface. and it seems to work well. and I can hear the sound while listening to video while it is recording. However once I try to watch the video in something like microsoft media or something I have no sound. I have the cable TV CATV video cable hooked up and then a cable going from the sound output on the video card going to the import spot of the camputer. So Since I can here sound while recording why can I not hear anything while watching the recordrd video?
That should work, but perhaps something is muted or turned down in your audio properties in Windows?
Other possibility is you don't have a codec installed to play back the audio type that the card records in. -
or possible the sound is not actually being properly recorded and you are only hearing it directly through the mixer..
I am just a worthless liar,
I am just an imbecil
Any way to record sound from PC using USB Headset?
By stranno in forum AudioReplies: 4Last Post: 7th Apr 2012, 03:34 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
How to record sound over the movie... Voice Over? Dubbing?
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 19:23 -
How do I record a my voice at a good sound level?
By OM2 in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2007, 13:31
