Can someone explain or direct me to a thread that helps explain what is going on when you are capturing screen shots from a DVD. I have a friend who asked me how to get full-size "full resolution" screen shots off a DVD. He said he tried WinDVD but at full screen it gives him half or quarter resolution captures. I had no clue so I did some searching and figured to tell him just use PowerDVD or VLC like everyone recommends in the sticky thread, but after trying to understand what governs the resolution of a DVD screen capture, I became confused. It seems that the size and settings of the monitor would ultimately decide the resolution of the picture. Is there any way to strip a frame from a DVD independent of a monitor? Thanks for the help and knowledge guys and gals.
aedipuss is correct that the screen cap you are getting is 720x480 resolution for NTSC dvd. While your monitor is most likely set to something like 1024x768 to 1280x1024 or even higher. Making the screen cap image appear smaller when viewed at its normal size - because it is. Put simply, when you view it Fullscreen on your monitor you are seeing a 'stretched' image if your screen is set to a higher resolution. Hope this helps.
Cheers,
RickRene: Could you not just wound him a little bit?
Hans: Well now, with a 25 pound shell that is not easy.
'Allo 'Allo -
Are you saying that 720x480 is the highest resolution that standard DVD's put out? Just out of curiosity, what is it for Blue-Ray? Also how does the resolution, like 720x480 correlate to the 1080i/p thing. I believe DVD's are 480p like old PS2 games. Thanks for all the responses.
Screen Resolutions
By ranosb in forum Video ConversionReplies: 4Last Post: 25th Aug 2009, 02:04 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 12:13 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 15:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 11:48
