    Jul 2007
    Australia
    hi all,
    I used GOTSent (fantastic program) to re-encode, well actually it dosent actually re-encode all the time, here is the cool thing, it extracts the video and audio streams and checks if they will work with the PS3, if they dont it will re-encode them so they will and if they are fine it just puts them in to a new container that the PS3 supports. So yeah i did this but the file is 11.7GB which wont fit on to a FAT32 formatted hard disk, I need to split it into smaller files so that I can smack it on to a hard drive and enjoy it on my PS3
    I ticked the option in GOTSent for it to do this for me but it didnt work.
    thanks
    You can cut mp4 with YAMB. Or you could try mkv2vob also, works similiar as gotsent.
    YAmb cutting:
