So I am remuxing my mkv's to m2ts for my ps3... and I know that only SRT subs will display on the ps3.
My problem is that the bottom 3/4's maybe even smaller of the subtitle line gets cut off when replaying... There is plenty of space during playback on my pc.
I looked at the SRT, and all it has is time and text... also opened it with subtitle workshop but it doesn't seem to show anything that can help... along with mkvmerge and mkv2vob.
Is there anyways I can fix this? The video is not zoomed while playing on the ps3 and its a 1080p... Would I have to shrink it down a but to create a bit of blackbar space which requires encoding? (not muxing or transcoding)
Or is there another subtitle format that I can use?
Thanks for your time and help.
Seedin and encoding... Healthy pc life :)
You can't change position in srt, you must change that in the video player. And if the PS3 ONLY supports srt you can't do much if you don't want to reconvert with burned in subtitles.
I would search in a ps3 forum like http://www.ps3forums.com/ for more information.
How do i display SRT & SUB subtitles on Media Player Classic
By alih786 in forum SubtitleReplies: 11Last Post: 21st Jun 2020, 03:29 -
Srt File cannot display color expect white
By fantest in forum SubtitleReplies: 7Last Post: 30th Oct 2011, 17:24 -
NBOX media player doesn't display the spanish subtitles srt properly
By leonardo07746 in forum Media Center PC / MediaCentersReplies: 0Last Post: 20th May 2011, 10:08 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 01:46 -
srt subtitles don't display properly
By briligg in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2009, 14:12
