I plan on connecting my MBP to my TV using DVI out and optical out. Note that I haven't actually tried to hook anything up yet- this is all speculative.
So I was ripping DVDs with Handbrake using the Apple TV settings, but then I heard that most receivers don't handle AAC format. I know that there's a hidden AC3 stream that handbrake includes. Will my receiver be able use this stream easily? or do I need to change some settings?
Also I considered just ripping everything as MKV's with AC3 audio- then in QTP saving those files at .MOV files. Is there really any drawback to doing this? Just seems like it would be a better choice for me - since I'm not using the Apple TV.
Also is there anything else I should keep in mind? Thanks
	with my MBP, I use Apple's DVI2Video adapter and run the video into
 my tv using S-VHS. For the audio, I use a standard Y audio cable from
 Radio Shack (1/4" to RCA Stereo). I set the MBP to mirror out
 onto my TV.
 I play all DVD Content ripped to the HD using VLC
 ( I rip Main Feature only), in FS, and just cue one after the other.
 *shrugs*
 No transcoding to other files, unless I plan on putting it on the iPod
 so that the wife can watch at a later date. If so, I use Visual Hub to
 make iPod 5G ready files from the ripped content.
 I don't rip a lot, only the stuff I know I can watch on lunch on the MBP
 and then finish later at night ( like episode TV) or movie series
 (Currently watching the Showtime Masters Of Horror series I picked up
 for cheap at a couple of Hollywood Video's that have closed down.)"Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
  What Conversion do i Need To Watch DVDs ???By musicmad in forum MacReplies: 4Last Post: 5th Apr 2012, 07:21
  easiest way to rip dvds WITH dual audio to MKV or AVIBy angryassdrummer in forum DVD RippingReplies: 13Last Post: 19th Dec 2011, 01:40
  rip blue ray and watch it on computer (no encoding)By chadkan in forum Authoring (Blu-ray)Replies: 2Last Post: 10th Dec 2011, 05:59
  No audio on TV after hooking up laptop with HDMI cable.By jordy2324 in forum ComputerReplies: 5Last Post: 27th Jul 2009, 20:23
  Audio synch problem using MTR and ffmpegx to rip DVDs and encode for ipodBy becky_s in forum ffmpegX general discussionReplies: 1Last Post: 2nd Nov 2007, 02:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
