Hi this may be a dumb question but my sister has just returned from her honeymoon and my now brother-in-law has given me a Minidv camcorder tape of the holiday to put on to DVD as a surprise.
I have captured the tape via my Panasonic NV-DS55 (that shoots in PAL 4:3).
So far so good.
Gspot tells me the file is 16:9 pal but TMPGEnc 4 says it is 4:3.![]()
Can a 4:3 camcorder transfer a 16:9 tape properly without loosing part of the original picture?
Cheers
thanks
Yes. DV format records wide as horizontally compressed in a 720x576 frame resolution. 4:3 is also recorded less horizntally compressed (for PAL) to 720x576. The difference is pixel aspect ratio. Editing software allows you to ID a particular clip as 4:3 or wide usually in file properties.Originally Posted by wozmacRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You can open the file in our Enosoft DV Processor which will show you exactly what aspect ratio the DV is (not the AVI file etc).
John Miller -
Thanks it says 16:9.
The prog looks like it has some useful features.
Thanks again.thanks
need to transfer videos from hi8 camcorder to pc
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2010, 18:42 -
Video transfer from camcorder to PC
By tony_baruti in forum Capturing and VCRReplies: 6Last Post: 25th Nov 2009, 12:33 -
EASIEST camcorder technology to transfer to PC?
By Xenogear900 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 29th Jan 2009, 17:50 -
transfer from camcorder to computer
By stratman in forum Newbie / General discussionsReplies: 4Last Post: 29th Sep 2008, 11:07 -
DVD from camcorder won't transfer
By mrtunes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 29th Aug 2008, 16:22
