Can someone point me in the right direction, as to how to setup Dr. DivX to output readable subs?
The ones it currently outputs are a big, fuzzy, white font that is difficult to read. I am inputting VOB
files ripped from DVD.
Is a plug-in needed? If so, which one and how is it setup?
Thanks in advance.
-The Mang
DVD/VOB subtitles are images so it's not that simple to make them look nicer. It should be possible to resize them but I don't know any tool that does it. If you want a new font you have to convert the subs to text using OCR using for example subrip or dvdsubedit.
Blurry Video Output from Premiere Pro CS5.5
By flyinthecoop in forum EditingReplies: 3Last Post: 24th Oct 2011, 22:23 -
Blurry output in Adobe Premiere Pro
By Thread7 in forum EditingReplies: 11Last Post: 10th Jan 2011, 10:40 -
Ulead Videostudio Output a Bit Big?!
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2009, 14:47 -
HELP svcd2dvd output too big for a dvd
By scaffers in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Nov 2008, 14:42 -
Subtitles muxed with IFOEDIT are always green and blurry
By Barse in forum SubtitleReplies: 2Last Post: 7th May 2007, 08:50
