Any help with this would be awesome and much appreciated.
This is the log:
Encoding started on Tue Apr 22 10:36:28 PDT 2008
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, mpeg, from '/Users/waltwity/Desktop/movie_01.mpg':
Duration: 00:00:16.7, start: 0.569733, bitrate: 768 kb/s
Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg1video, yuv420p, 368x272, 600 kb/s
Stream #0.1[0x1c0]: Audio: mp2, 32000 Hz, mono, 32 kb/s
Output #0, flv, to '/Users/waltwity/Desktop/fog.flv':
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 320x240, q=2-15, 200 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
frame= 600 q=7.8 Lsize= 712kB time=20.0 bitrate= 291.5kbits/s
video:554kB audio:137kB global headers:0kB muxing overhead 3.097069%
bench: utime=5.149s
sh: /Applications/ffmpegX.app//Contents/Resources/flvtool2: /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/bin/ruby: bad interpreter: No such file or directory
It seems the video and audio were encoded fine.Originally Posted by waltwity
A problem with (the location of) 'Ruby' may prevent the flvtool2 to include meta data in the (otherwise perfectly fine) output file.Originally Posted by waltwity
Here's a how-to for fixing that: https://forum.videohelp.com/topic345126.html#1807644
That did! Thanks a bunch. That worked in OS 10.4. I tried editing the flvtool2 in text editor for Mac OS 10.3.9 but gave me "failed" in the progress app. Is there a special tweek in Mac OS 10.3?Originally Posted by Case
This is the log:
Input #0, mpeg, from '/Volumes/walterflores/Public/thm_01.mpg':
Output #0, flv, to '/Users/walter/Desktop/04.flv':
Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
frame= 241 q=4.5 Lsize= 705kB time=20.1 bitrate= 287.7kbits/s
video:552kB audio:137kB global headers:0kB muxing overhead 2.290624%
bench: utime=3.140s
ERROR: undefined method `to_int' for 19000:Float
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:181:in `add_meta_data_tag'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:137:in `update'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:47:in `send'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:47:in `execute!'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:46:in `each'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:46:in `execute!'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:44:in `process_files'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:225:in `each'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:225:in `process_files'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2/base.rb:44:in `execute!'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2.rb:168:in `execute!'
ERROR: /usr/local/lib/ruby/site_ruby/1.6/flvtool2.rb:228
ERROR: /Applications/ffmpegX.app//Contents/Resources/flvtool2:2:in `require'
Encoding completed on Wed Apr 23 10:38:00 PDT 2008
Converting .mov or .avi to flv does not work
By Alainb2809 in forum ffmpegX general discussionReplies: 22Last Post: 11th Oct 2010, 14:33 -
Why do some of my conversions scale on my display, others don't?
By tonyp2 in forum Video ConversionReplies: 12Last Post: 10th Sep 2010, 07:24 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 12:51 -
Divx to FLV to MOV to FLV again, just for the sake of some effects?!
By ayyash in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2008, 21:19 -
YouTube (.flv) to QuickTime (.mov) on Mac OS X 10.4 doesn't work
By sailmariner in forum MacReplies: 4Last Post: 3rd Jul 2007, 08:09
