Is there a tool to create a .exe from a Quicktime mov?
Thanks,
Leo
It works great, thanks again.
Just curious, I made a MOV, is it playing back with its own player
or the Windows Mediaplayer? -
It's using Mplayer which is different than Windows Media Player. What happens when you click on the newly created EXE is this:
1) The original MOV and the player get unzipped out of the EXE file and are copied into the Windows temp folder.
2) Mplayer is instructed to play that particular MOV
Best .mts to Quicktime .mov converter?
By nojiri in forum Video ConversionReplies: 3Last Post: 28th Jun 2010, 18:54 -
I can't edit this mov quicktime file
By qisheng in forum EditingReplies: 19Last Post: 1st Dec 2009, 03:05 -
joining MOV files with quicktime
By natty in forum Newbie / General discussionsReplies: 5Last Post: 30th May 2009, 09:18 -
Quicktime/MOV files in TmpGenc
By buddycat in forum Video ConversionReplies: 2Last Post: 20th Mar 2009, 21:54 -
quicktime (.mov) conversion
By superstarx85 in forum Video ConversionReplies: 0Last Post: 11th May 2007, 04:10
