Kayembee - Does the mencoder trick work for VFR .mkv's?
The only 99.99% sure way (for me at least) for all VFR files is to use avisynth DirectShowSource("Path\file",fps="x",convertfps=tr ue), where "x" is the true fps. MeGUI's audio (based on BeHappy) uses avisynth for audio and this syncs everything up when you use the same script for audio & video. Basically if you can playback in sync, it will work. No need to strech or shrink audio/video
Results 31 to 34 of 34
Dunno, and I have no VFR mkvs to try it on. I'd say give it a whirl, use a VFR mkvOriginally Posted by poisondeathray
instead of a wmv as input, and tell us what happens.
As for using AviSynth with a specified frame rate based on the actual frame rate
(max or average), it doesn't work for me on these VFR wmvs. I get both
audio desynchronization and intermittent video smearing when I've tried. -
Sorry for posting to an old thread
This small tool also should be able to extract the audio stream from a WMV file:
http://code.google.com/p/mulder/downloads/list?can=2&q=wma2wav
(including sourround sound support and VFR sync correction)
Problem Extracting files over 4gb
By PSS2 in forum Software PlayingReplies: 5Last Post: 4th Apr 2010, 21:27 -
Extracting Audio from M2TS Files
By foochuck in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 31st Mar 2010, 18:30 -
Problem with WMV files with longer audio than video
By Jumpe in forum Video ConversionReplies: 2Last Post: 26th Jun 2009, 14:00 -
Extracting/demuxing a .TS into separate video and audio files?
By mkvbob in forum DVB / IPTVReplies: 10Last Post: 25th Jul 2008, 03:15 -
Extracting audio from video files (Other few questions)
By Mickz in forum Newbie / General discussionsReplies: 14Last Post: 25th Feb 2008, 15:47
