whats the difference????
Look to your left <<<<<<<<<<
Under "What is" - "DVD" and "VCD" -
cd's hold roughly 650 meb of data
dvd disc hold 4.2 gigabyte of data , thats 7 cd's
a double layer dvd holds 8.4 gb data = 14 cd's
thats the major difference, its the same technology carried to a higher degree. after that its sectoring, file allocation, type of data involved and read speeds have to be much higher to read the greater amount of data
whats the difference between a single cylinder gas engine and a 10 cylinder 40 valve fuel injected 600 hp engine. ? -
Interesting analogy.
VCDs also use MPEG-1 format with 44.1Khz audio, while a DVD uses MPEG-2 most times with 48Khz audio. -
It makes sense to watch VCD on a 3.5" display on PDA or portable player with solid state memory.
It makes sense to watch DVD on a regular or large screen TV. -
redwuz,
The question is do you know why they are 44.1KHz audio or higher. I'm just playing around, not trying to start anything btw.
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
what is difference to + and - DVD-R and RW?
By snadge in forum DVD RippingReplies: 2Last Post: 27th Feb 2008, 12:14 -
What’s the difference between the DVD Shrink3.2 and Rebuilder?
By coody in forum DVD RippingReplies: 5Last Post: 27th Feb 2008, 11:17 -
HD-DVD players. What is the difference?
By mmcguigan in forum DVD & Blu-ray PlayersReplies: 18Last Post: 19th Feb 2008, 11:43 -
Verbatim DVD+R DL Inkjet - any difference?
By pstedman in forum MediaReplies: 2Last Post: 20th Jun 2007, 16:50
