I have a miniDV camcorder (Sony DCR-TRV33) and the quality is poor when converting with a USB cable.
Also, winDV does not recognize the USB cable for some reason.
Will buying a 1394a cable + PCI card fix the problem? And if so, where is the best place to buy it online?
This one comes with a cable: http://www.newegg.com/Product/Product.aspx?Item=N82E16815265002
I don't know if WinDV will work with a USB connection, but it works fine with FireWire. -
The USB cable is for low resolution WebCam use. You need ilink (firewire) to get full resolution. WinDV only works with firewire.
Buy My Books -
Interesting.
Just to verify... 1394a = Firewire, correct?
The terminology confuses me. -
yes and it's also referred to as ilink sometimes.
Firewire=1394a=i.LINK. All the same, just different names. From Wikipedia: http://en.wikipedia.org/wiki/FireWire Sometimes also called FireWire 400 as there is now a FireWire 800, but not in common use at this time.
neweggneweggnewegg
been using them for years, shipping to doorstep in under 2 days, never an issue with an RMA, best price and service on the web, period.
EDIT:
also be aware that firewire comes in different sizes. VERIFY what type of connection your camera accepts. the plugin to the computer is universal.
Need to buy a suitable PCI X firewire card for my newish PC ASAP
By Canon GL-2 Guy in forum ComputerReplies: 2Last Post: 5th Sep 2011, 00:08 -
Capturing VHS/Cable - What to buy?
By rbxbots in forum Capturing and VCRReplies: 14Last Post: 15th Aug 2010, 19:56 -
Buy AGP 2x/4x or PCI video card ?
By SingSing in forum ComputerReplies: 10Last Post: 26th Apr 2008, 11:24 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
