I have bought a DVD with a movie that has only English subs. I would like to add Dutch subs without losing the English ones. I have ripped the DVD to a single VOB file with MtR (the English subs were still there) and then tried authoring a DVD in ffmpegX using the mpeg2encoder whereby I included the Dutch subs by way of an .srt file in the Filters tab. It didn't work. That's to say, the Dutch subs are there but the English ones have now vanished. Is it maybe impossible to do what I want? Or if it is possible, how should I go about it? Thanks in advance.
Results 1 to 10 of 10
ffmpegX doesn't have the ability to author two subs.
Perhaps you need a full featured authoring app like DVD Studio Pro...
Your options on the Mac are indeed limited, if you don't want to spend (much) money. If you have access to a Windows machine, you have a bit more flexibility. Some "How to" guides from this site that might be of interest are:
https://forum.videohelp.com/topic245188.html
and
https://forum.videohelp.com/topic275603.html
These aren't simple "one-click" operations, as you can see, so they may not be appealing to you. But perhaps these examples give you some idea of what is involved.
I had a feeling it would be impossible on the Mac with the apps that I have, but buying DVD Studio Pro is hmm... a bit much right now. I have no Windows machine, but a good friend of mine has (poor soul). I have already printed out the guides and hopefully I can make it work. Thanks guys.
Oh my... hit a nerve there me thinks...
But anyway, it's very well possible to include 2 subtitles, just not with the freeware apps I use. Like the man said: for DVD Studio Pro it's a piece of cake.
As a workaround (albeit a somewhat cumbersome one), perhaps you might consider authoring two separate DVDs, one with Dutch subs, and the other with English subs.
I know it's inconvenient to have to make two separate DVDs just to accommodate two subtitles, but with the tools at hand, perhaps it's not a completely unreasonable compromise solution.
Just a thought.
Yet again: how add .srt subs to .avi for burning on DVD?
By VenusAndMars in forum Authoring (DVD)Replies: 10Last Post: 17th Jan 2011, 02:34 -
Xml tags when adding srt subs to mkv with mkvmerge gui?
By branch in forum SubtitleReplies: 0Last Post: 15th Mar 2010, 00:11 -
Burning DVD and Subs/Srt's
By Wanderlustus in forum Authoring (DVD)Replies: 4Last Post: 11th Sep 2009, 23:56 -
Removing scenes from DVD while keeping original Menu?
By saini in forum Newbie / General discussionsReplies: 1Last Post: 25th Oct 2007, 23:42 -
converting .avi (divx) to dvd and keeping original quality...
By RushMaster in forum Authoring (DVD)Replies: 15Last Post: 22nd May 2007, 15:47
