I'm looking at buying a new receiver/amplifier, but am a little unsure of the subwoofer connection. My subwoofer (which I guess is a little old now) only has 1 input jack. This new receiver says it comes with 1 subwoofer output, but this output has 4 output jacks. What would be the best way to connect this new amp to my subwoofer? ... because I really can't afford a new subwoofer now too. Thank you very much!
Picture: http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/img/products/STRDG910_rearpanel.jpg
u need a wire with RCA connector on one side that plugs into the receiver - try any of the 4 plugs one has to work (likely one of the 2 on the bottom,)
and the other end of the wire needs to plug into your subwoofer - if your sub is self powered (gets power from the electric socket),
if its not self-powered you got a passive sub .... which wont do any good to plug in the sub-out of the receiver 'cos that has just low level output....you can try plug it in one of the speaker outs of the receiver...but probably wont sound like a subwoofer...
problem connecting computer to telly using vga cable
By xtube in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2010, 03:01 -
Connecting a TV, cable box, and VCR/DVD
By jmarsico in forum Newbie / General discussionsReplies: 11Last Post: 31st Jul 2010, 19:31 -
HELP! Connecting cable box to computer for HD Recording
By wickedwheels in forum DVB / IPTVReplies: 16Last Post: 29th Aug 2009, 21:25 -
Problem with Connecting my Cable TV recevier with TV Card
By hadivelko in forum Capturing and VCRReplies: 2Last Post: 16th Feb 2008, 11:04 -
Connecting Bellexpressvu box to current cable setup
By samouellette in forum DVB / IPTVReplies: 1Last Post: 29th Nov 2007, 09:41
