hi, I'm no newbie to video editing, but am to ffmpegx. Basically, I have an avi and the subtitles are in a text file, is it possibly to use ffmpegx to somehow embed or merge the subtitles to the video so that I can burn it to dvd and retain subtitles? The second part of my questions is this: the avi contains dolby digital 5. audio(ac3), I'd like to keep this audio exactly as it is, is that possible? I tried deselecting the encode audio option, but then the summary shows no audio, does that mean that no audio will be included? Thanks in advance.
	Yes you can. A procedure is described on http://www.ffmpegx.com/dvd_sub.htmlOriginally Posted by kaoticone
 Try the Passthrough option. (If that fails, set audio to AC3 with the same parameters as the source (bitrate, sampling rate, number of channels, bitrate mode).)Originally Posted by kaoticone
 De-selecting 'encode audio' will prevent the audio from being included in the output file.Originally Posted by kaoticone
  Help with converting video / adding subtitles - subtitles are off from audiBy kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53
  MKVToolnix muxing problem when adding or removing audio and subtitlesBy firstliight in forum Video ConversionReplies: 1Last Post: 19th Nov 2010, 09:23
  adding subtitlesBy dabud in forum Authoring (DVD)Replies: 3Last Post: 20th Oct 2009, 23:27
  Adding subtitlesBy tommcd64 in forum Authoring (DVD)Replies: 7Last Post: 28th Aug 2009, 01:39
  Adding subtitlesBy Avril in forum MacReplies: 14Last Post: 18th Jan 2009, 14:43
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
				 Visit Homepage
				Visit Homepage
