When I make a vcd and play it on my stand alone dvd,smoetimes it plays really choppy. Why, and how can I stop this?
does it do the same thing on the computer... if not it may be the dvd player or the media you are using... if it does do the same thing on the comp then it is somewhere in your vcd creation proccess.
Please try not to "bump" your topic back to the top (it's annoying) and try to have some patience. This is a bulletin board, not IRC. It may take some time (e.g., one or two days) before someone can answer your query or question.
It only does it when I play it on ny stand alone dvd player. So does that mean its my players falt and not mine. But it doesn't do it all the time. And Im useing the same cdr's
Sometimes a DVD player will say it's compatible with VCD's but not altogether. My GO Video (from Samsung) said it was, but also played choppily. So for my next puchase, I brought the media down to the store (VCD CD-R, VCD CD-RW, MP3 CD-R) to test. The Panasonic 31K worked beautifully (and still does) - less than $200.00.
Hi How are you ripping it from disk and how and what with are you encoding it with ?
try encoding like for like. if you play the VOb in DVD2avi it will tell you if the video is Progressive or interlaced make sure that you encode has the same has the Vob is done This has worked for me also if its VCD make sure in are using the VCD standard and not some XVCD. eg 1150Kbit for vid and 224k for audio fr a true vcdCHEERS GARRY -
Im converting it from avi. to mpeg. When I play it back it plays fine. When I burn it , the audio and video gets chopy as in "pauses every 2 to 3 sec". I tried to burn it with nero and EZcd 5 and still does the same thing. Can my CPU or my burner cause this, or even somethig running at the same time cause this. I dont think anything is running when I burn.
thanks
Chop it up!?
By cnknightro in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2012, 08:02 -
How to chop n edit .m2ts file?
By Bonie81 in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2010, 05:16 -
Slap Chop...any good?
By ron spencer in forum Off topicReplies: 14Last Post: 14th Jun 2009, 08:36 -
mpg...compress and chop
By astro604 in forum EditingReplies: 3Last Post: 1st Mar 2008, 18:50 -
How to chop out a section in middle of .flv file without reencoding
By Toastie in forum EditingReplies: 0Last Post: 15th Jul 2007, 18:54
