I recently purchased a JVC 1080 HD camcorder that records video to the HDD as .TOD files. Now since I need to get these files to a format that I can work with for my software (in order to burn to BlueRay), I want to make sure that I have the best possible video with no loss of quality.
At the bottom of this post, I have pasted the video info which I am confused about:
#1. The info on an original .TOD file recorded.
#2. Using Streamclip, I converted the .TOD to a headed MPG (not sure if this just changes the header or is a full transcode?)
#3. Is a full MPG recode using Streamclip
#4. Was created using VLC to only change the encapsulation of teh TOD --> MPG
#5. Is the full .TS conversion using MpegStreamclip
Ok so here are my questions:
1. - It looks as if the .TS conversion creates an alomst exact file (Fames/Audio etc) for a perfect copy.
2. - As I would rather work with MPG due to the nature of the programs that all support it however:
Each one of the below MPG files whether converted ot just encapsulation change seems to have less video frames and audio???? Is this a loss in both video and Audio qualitiy from the original file, or is this just due to the inherent differences between TOD/TS and MPG? Can someone explain these differences?
3. - What is the general consensus is TS better to work with or is MPG?
Again, I want to get these files to Blueray so I do not want any qualityloss. Any help would be greatly appreciated.
MV
#1.
Stream: MOV001.TOD
Path: E:\MyWorks\Test\MOV001.TOD
Type: MPEG transport stream
Duration: 0:00:07
Data Size: 28.88 MB
Bit Rate: 30.32 Mbps (?)
Video Tracks:
4113 MPEG-2, 1920 x 1080, 16:9, 29.969999999999999 fps, 28.00 Mbps, upper field first
Audio Tracks:
4129 MP2 stereo, 48 kHz, 384 kbps
Stream Files:
MOV001.TOD (28.88 MB)
#2.
Stream: MOV001_headed_MPG_Streamclip.mpg
Path: E:\MyWorks\Test\MOV001_headed_MPG_Streamclip.mpg
Type: MPEG program stream
Duration: 0:00:07
Data Size: 27.36 MB
Readable: 27.36 MB
Bit Rate: 28.96 Mbps
Video Tracks:
224 MPEG-2, 1920 x 1080, 16:9, 29.969999999999999 fps, 8.00 Mbps, upper field first
Audio Tracks:
192 MP2 stereo, 48 kHz, 384 kbps
Stream Files:
MOV001_headed_MPG_Streamclip.mpg (27.36 MB)
#3.
Stream: MOV001_Streamclip.mpg
Path: E:\MyWorks\Test\MOV001_Streamclip.mpg
Duration: 0:00:07
Data Size: 27.36 MB
Video Tracks:
Audio Tracks:
Stream Files:
MOV001_Streamclip.mpg (27.36 MB)
#4
Stream: MOV001_VLC_TS.mpg
Path: E:\MyWorks\Test\MOV001_VLC_TS.mpg
Duration: 0:00:07
Data Size: 26.13 MB
Bit Rate: 27.84 Mbps
Video Tracks:
69 MPEG-2, 1920 x 1080, 16:9, 29.969999999999999 fps, 28.00 Mbps, upper field first
Audio Tracks:
68 MP2 stereo, 48 kHz, 384 kbps
Stream Files:
MOV001_VLC_TS.mpg (26.13 MB)
Stream: MOV001_Streamclip.ts
Path: E:\MyWorks\Test\MOV001_Streamclip.ts
Duration: 0:00:07
Data Size: 28.00 MB
Bit Rate: 29.64 Mbps
Video Tracks:
Audio Tracks:
Stream Files:
MOV001_Streamclip.ts (28.00 MB)
What blu-ray authoring tool are you going to use? You might not have to convert the mod to ts or mpg, it may be enough to just rename to mpg. I would try author the mod/mpg files to a blu-ray using nerovision or ulead dvd moviefactory. If it take several hours to convert/burn then it will reconvert = lose quality.
