Hello
I sometimes prepare master CD or DVD for mass produces.
I need to check quality and format accuracy of a replicated or recorded disc.
I'm looking for software for verify/analysis images.
Most replicators use Eclipse Suite software e.g. ImageAnalysis CD/DVD
but the price of ImageAnalysis starts around 5.000,- Euro.
It is too expensive for me.
Do you know another cheaper software?
Nero CD-DVD Speed is free and can do quality checks. ImageAnalysis is probably better, but maybe Nero CD-DVD Speed is good enough for your needs.
I know Nero Speed but
the software should verify files in VIDEO_TS folder (DVD-Video structure) - authoring correct (yes/no/warning/error etc.) -
grzegorz,
An alternative to buying the software might be to pay someone else to perform the testing for you. For example, TFDVD Research Labs seems to have a pretty flexible menu of services including Eclipse Image Analysis and MEI DVD-Video Verifier testing. You can take a look at what they offer (and what they charge) to see if it's something you could use.
Recommend fast & small (few system resources) DVD utilities quick analysis?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2010, 16:37 -
Capture quality analysis and vectorscope software
By cybertheque in forum Capturing and VCRReplies: 15Last Post: 12th Oct 2008, 12:35 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26 -
DVD Recorder models - Picture Quality and Features Analysis
By trhouse in forum DVD & Blu-ray RecordersReplies: 113Last Post: 8th Feb 2008, 02:22 -
Audio analysis software needed
By Nelson37 in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2007, 00:17
