Hello all,
I captured a footage dv source and it got some grainy vertical lines in some parts of it for few seconds because the capture was from remote wireless cam and transmission was weak. What is the best filter to use to enhance quality?
I have adobe premiere, ulead and power director but can’t figure out which filters to apply
Attached is a sample shot
Thanks for any help
I doubt any filter will fix that.
About all I can suggest is to blur it if you can't cut it out. Or substitute a still picture if the audio track is still good.
was thinking to subsitute with video from the outside since audio track is ok
thanks
vhs video capture bad sound
By lulu15 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2011, 21:59 -
Bad screen capture
By Khalua in forum ComputerReplies: 1Last Post: 9th Mar 2011, 17:44 -
How to repair dvd with corrupt sectors AND bad video_ts.ifo?
By Spixe in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2010, 08:54 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Premiere CS3 bad capture results
By LSchafroth in forum Capturing and VCRReplies: 6Last Post: 15th Mar 2008, 14:17
