http://www.amazon.com/Hauppauge-WinTV-HVR-950-Hybrid-Stick/dp/B000RHVOJM/ref=cm_cr_pr_pb_t
http://www.amazon.com/Hauppauge-1139-WinTV-HVR-950-External-Recorder/dp/B000J1CCGA/ref...8745169&sr=1-1
Other than the software provided, is there any difference? And if anybody used these products, is the CPU Usage really that high? By the way, I'll be using my school's cable provider to get the cable channels.
Seem to be different generations of the same product.
The wrap on the 950 is that it supports over the air ATSC/NTSC but not cable QAM. It was a first generation product that lacks raves. Read user reviews carefully.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Other products like the dazzle?
By darklink502 in forum Video Streaming DownloadingReplies: 3Last Post: 19th Mar 2012, 21:47 -
ION products anyone used them?
By victoriabears in forum Capturing and VCRReplies: 0Last Post: 14th Sep 2009, 00:04 -
TMPGEnc Products - Notice Difference
By niteghost in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2009, 20:15 -
TMPGEnc 3.0 products vs new 4.0 products?
By Valnar in forum Authoring (DVD)Replies: 6Last Post: 14th Jan 2009, 16:38 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 20:14
