I am using SUPER to convert rm. I tried to convet to wmv, flv and avi. But when I view the output video, the video quality looks SO bad, more worst than the original video quality even if I change to higher bitrate .
Here's my video detail:
General #0
Complete name : K:\HZ\06a.rm
Format : RMF
File size : 42.1 MiB
PlayTime : 25mn 51s
Bit rate : 225 Kbps
Copyright : ©2000
Video #0
Codec : RealVideo 3
Codec/Info : Between H263 and H264, RealVideo 8
PlayTime : 25mn 49s
Bit rate : 193 Kbps
Width : 352 pixels
Height : 288 pixels
Display Aspect ratio : 1.222
Frame rate : 25 fps
Resolution : 12 bits
Bits/(Pixel*Frame) : 0.076
Audio #0
Codec : Cooker
Codec/Info : Real Audio G2/7 Cook (low bitrate)
PlayTime : 25mn 51s
Bit rate : 32.1 Kbps
Channel(s) : 1 channel
Sampling rate : 22.05 KHz
Resolution : 16 bits
You will want to keep the same resolution and the same or higher bitrate. There will be some quality loss. Any and every conversion reduces quality. Aside from that, it is likely an issue with the tool being used.
Google is your Friend
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
Problem Converting Video Format
By jb2135 in forum Video ConversionReplies: 6Last Post: 5th Jul 2009, 14:06 -
problem converting to mp4 with super
By cduval04 in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 11:42 -
Problem converting avi to dvd format with Avi2dvd
By bgart13 in forum Video ConversionReplies: 0Last Post: 13th Apr 2008, 16:27 -
Converting video files to .AMV format problem.....
By TheGMan in forum Video ConversionReplies: 2Last Post: 26th Dec 2007, 02:45
