I've got a Samsung HD870 DVD player and when I try to play a DVDRW on it, the beginning sequence is shown, then it skips immediately to the credits. It works fine on my PC, is this a good indicator of a good burn?
Thanks.
What brand of DVD media are you using? Not all settop players will work with all brands of DVDRW. I would try some different brands.
What programs did you use create the DVDRW and burn it with?
Playback on a PC doesn't mean much as they are much more tolerant of problems than a settop player.
And welcome to our forums.
DVD Shrink can't burn by itself. It either uses Nero or DVD Decrypter, depending on the settings. I don't use DVD RW very often, but I would try a different brand, maybe Verbatim. And if you are using Nero for burning, try ImgBurn. It can burn either a ISO or a VIDEO_TS folder from DVD Shrink. Also, unless you plan to reuse the DVD disc, you could try a regular DVD, not RW.
No dialogue, but other audio works fine
By MCPorche in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2012, 21:07 -
M2TS File No Audio in Premiere (works fine in VLC)
By koberulz in forum AudioReplies: 22Last Post: 6th Oct 2011, 02:46 -
Problem playing newer 720p files (1080p works fine)
By twoplustwo in forum Software PlayingReplies: 5Last Post: 13th May 2010, 19:04 -
MTR 3.0 R14d works fine for Star Trek 9...
By Davey Jones in forum MacReplies: 3Last Post: 8th Dec 2009, 09:28 -
Problem with S-Video: only getting black/white, Composite works fine!
By x92 in forum Capturing and VCRReplies: 20Last Post: 22nd Jun 2008, 10:05
