I do believe my hard disk (C drive) is going out. During the disk check (see screenshot) some bad sectors were found. (Also, I'm having other strange problems that seem to indicate the drive is going out.) But my question is, where is that info (that part of the disk now cannot be used) stored? I mean, if I restore the C drive from a previous Ghost image, I assume the bad sectors will remain cordoned off, right? So certainly this "location of where is bad sector" info cannot be stored on the C drive, so I am wondering where it is stored? Is it stored in the bios or someplace like that?
Windows will lock those sectors out from being used. Where it stpres that information is the FAT table so yes a Ghost image restore will use them.
You need to use the drive makers utilities to replace bad sectors with spares.
However if the surface is going bad the it will keep going bad until it is toast. Reformatting or restoring a bad drive does not fix it.
new hard drive no windows disk
By luvvbuzz in forum ComputerReplies: 6Last Post: 4th Jan 2012, 12:41 -
AVCHD format to be stored in hard disk
By videohelpuser in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Aug 2009, 05:29 -
Hard Drive Info
By hardy in forum ComputerReplies: 8Last Post: 25th Jun 2009, 22:11 -
Bad Hard Drive - Not!
By videobread in forum ComputerReplies: 4Last Post: 11th Sep 2007, 15:47 -
installing windows me has a bad effect on my hard disk?
By ieh4f in forum ComputerReplies: 2Last Post: 10th Jul 2007, 13:02
