I am using Media Player Classic with CoreAVC 1.7.0.0.0 - AC3 filter
When playing MKV file it starts off ok but as soon as their is a scene change the audio goes out of stnc, also when the sound in the movie goes up the sound starts stuttering and stays like that onwards. If i jump foward through the video file it stays insync for awhile then does the above again.... Not sure if it`s just the computer spec...
	1280X528 with DTS audio. Yeah general AVI files are ok. The AC3 filter on the MKV file lets the audio play `as is` Screen resolution is 1920x1200
 I have kept it in the box of it`s resolution but now after playing high movement the picture starts playing like a slide show while the sound plays as normal, thing is it never stops after it starts same with the sound once it plays loud and starts stuttering it never stops.. Not sure if the data rate to high for the PC or a not flushing the buffer problem, if it has a low audio and movement part it plays ok for at least 10 minutes.....
	I think your system might be right on the cusp of being fast enough, but fast movement creates a A/V desync. Might be time for the new CPU/Mobo combo if you're going to be doing this a lot.
 Once last thing to consider - turn off deinterlacing in CoreAVC. That'll save a few CPU cycles.
	Yeah i have already upgrade in waiting with a X38 motherboard, 2Gb DDR2 (800Mhz), 750Gb WD RE2 HD, Geforce 8800GT but until i can buy a Q9450 available ....thats all waiting in their boxes.
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
  MKV Playback RecommendationsBy Khalua in forum Software PlayingReplies: 1Last Post: 7th Apr 2010, 14:11
  mkv playback problemsBy sumarIII in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 18:01
  MKV playbackBy unknownguy in forum Software PlayingReplies: 5Last Post: 8th Mar 2009, 13:01
  MKV playback strangeness...By mh2360 in forum Software PlayingReplies: 2Last Post: 16th May 2008, 18:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
