hai
i have a mobile JinpengA1188(china mobile).... the file explorer shows two files for each video.. one for the video and the other file for the audio.... i am not able to play 3gp or mp4 videos... i dont know which format does the phone support.. the only thing i know one file has an extension .vid and the audio file is in wav format. i have uploaded the video file.... can anyone help me to convert avi or 3gp videos for the format in the attached video? thanks in advance.
http://www.uploading.com/files/2SLN..._video.rar.html
I get a page not found on this server message from your link.
While you sort that out, you might also try Video Inspector or Media Info to find out what type of video the file has.Read my blog here.
ok fine i will upload the file from the option below.... thanks for ur reply....
china%20mobile%20-%20vid%20format%20video.rar -
The .vid file is a .mjpeg file rotated 90 degrees to the right..
If you have the mjpeg codec, use VirtualDub with the rotate filter and save to Divx/Xvid. -
thanks a lot.... the solution u have given is to play the video in my PC... this solution works... thanks..... but how can i convert an avi file to this mjpeg format and play it in my mobile?
Video Format and Conversion Questions
By djtech2k7 in forum Newbie / General discussionsReplies: 20Last Post: 9th Jan 2012, 21:26 -
I need to choosing a video conversion format
By Cralis in forum Newbie / General discussionsReplies: 17Last Post: 17th Jan 2010, 03:59 -
Open source video format conversion engine
By TrupsT in forum Video ConversionReplies: 2Last Post: 2nd Feb 2009, 08:32 -
Video format conversion for Mac
By Scotty427 in forum MacReplies: 3Last Post: 10th Aug 2008, 11:33 -
ADVICE NEEDED... as of today, what is BEST vid format to convert DVDs???
By carapalida in forum Video ConversionReplies: 4Last Post: 7th Oct 2007, 17:39
