My work laptop won't burn CDs. It goes through the motions and spits out the disc after when it is finished but comes up saying it's blank when I insert it.
Since it's my work computer, I can't even recall if I ever burned disc on it. It is a CD-RW/DVD drive. Any settings to check? The box is checked to enable the drive to burn.
Thanks!
If it's a company computer, you may not be able to do this, but I would add ImgBurn. It does burn CDs also. And it has a few tools to test the drive. But what burning program is it using presently? Most times with XP, it's some version of Roxio if you are using the OS burning setup. ImgBurn is likely a better choice.
It doesn't sound like the problem, but many laptop drives have the laser lens exposed when the tray is open. It may have a chunk of dirt on it. -
It has Record Now installed. I tried Deep Burner but had the same problem. It reads OK. I work in an extremely dusty environment. I've cleaned it as well as I could. I'll try ImgBurn.
Thanks! -
Well, it's still choking. The dust there is insane and I'm sure it fouled things up. It says it burned the disc successfully but just hangs when I try to open it in that or my home computer. Discs burned elsewhere read fine.
Time to get another drive - on the company!
Pioneer DVR118L Won't Burn CDs
By DarrellS in forum DVD & Blu-ray WritersReplies: 17Last Post: 12th Apr 2011, 03:36 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
video problems in IBM A31 Laptop
By mikehende in forum Newbie / General discussionsReplies: 10Last Post: 31st Jul 2009, 17:13 -
Live Video Streaming using Sony DCR TRV22 and IBM T42 laptop
By MESP2005 in forum Capturing and VCRReplies: 3Last Post: 16th Mar 2008, 06:52 -
Issues while connecting IBM T42P laptop with Sony 46" XBR3 lcd tv
By nikulb in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2007, 18:52
