After deleting some buttons (for blanked out vobs), the existing buttons (which get renumbered) no longer link to their proper vobs. This hasn't happened with other dvds. I don't know (or understand) how to reset the gprm values to keep the original links intact. I tried hiding the buttons but they're still active and selectable. Any suggestions how to do this?
Hi-
You shouldn't just Delete Buttons, but if you Hide Button->Jump To Non-deleted button, it won't cause any problems with the rest of them. And it won't still be selectable. -
That's what I did but when I go to the menu, none of the buttons are highlighted until I toggle around with the remote control. I figured it was because the hidden button was "highlighted;" when active, it's the first button and would be highlighted first. If this isn't the case, as you suggest, then the problem isn't with deactivating the buttons, it's with making sure an active button is highlighted when the menu is called. I know I could force-select a button to be active, but that would defeat that process where returning to the menu highlights the next button. Trivial, I know, but is there a way to maintain that?
I'm not entirely sure I understand, but maybe I do. If you hide the button that would normally be the first one selected and you go to that menu, nothing is highlighted. You'd think that "Jump To Non-deleted button" would make something light up when entering the menu. But if you hit "Select" on the remote control, it does look to me like it then goes to a non-deleted button like it's supposed to. I was testing this out using PGCEdit's Trace function. I'm not about to save it and test it in my standalone as I don't have any DVDs at the moment where I want to hide the first button in a menu. The button that was hidden is no longer active or selectable, though, as you seemed to be saying in your first post. The behavior is somewhat peciliar, I agree with you, but not much more than a minor annoyance, I don't think.
It's still way better than deleting a button and messing up the rest of the button commands, don't you think? You could always bring it up in the IFO/VOB Editors Forum at Doom9 where the developer, r0lZ, hangs out. He visits here sometimes as well, and maybe he'll see this thread. -
Originally Posted by spiritgumm
When Dialog box open where you choose Hide Button, there is an option "Jump to non deleted button". Check that and all is fixed.
PGCEdit menu editing
By gbabione in forum DVD RippingReplies: 3Last Post: 31st Aug 2010, 05:13 -
trying to jump over Aspect ratio menu with Pgcedit
By spiritgumm in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2009, 03:03 -
PGCedit fix menu buttons
By mark129 in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2008, 00:51 -
Pgcedit to go to main menu after a specific chapter?
By redsandvb in forum DVD RippingReplies: 4Last Post: 15th May 2008, 19:32 -
PgcEdit does not save buttons anymore
By kurbads in forum Authoring (DVD)Replies: 0Last Post: 29th Aug 2007, 10:26
