Closed Thread
    Apr 2008
    hello please help
    i am trying to copy my DVD RAM discs to a pc hard drive
    i have recorded many tv programmes to dvd ram discs
    using a normal home dvd recorder (panasonic dmr-e55)
    and now want to transfer all these tv programmes to my computer's hard disk WITH NO LOSS OF QUALITY
    i do not want convert the files to different formats etc
    i just want to perfectly copy all the separate tv programmes (dvd ram disc chapters) as they are
    so i can store all my tv programmes on the hard drive
    (and maybe in the future edit, crop and re organise them etc)
    can anyone tell me how to do it
    as i say it must be WITH NO LOSS OF QUALITY
    my problems have been
    i cannot just drag (copy) the contents of a DVDRAM
    it just comes up as one big single .vro file
    and some copying software i have looked at says convert encode etc etc and as i say I WANT TO BE 100% SURE i am not altering the quality of the tv programmes IN ANY WAY when i copy them (to make a perfect copy of each file as they exist on the DVDRAM disks now)
    please can anybody tell me how to do it
    if needs be i am willing to buy the correct software
    greatest thanks
    richard
  2. Member bendixG15's Avatar
    Aug 2004
    No upper case on your keyboard ?
  3. Member DB83's Avatar
    Jul 2007
    I do not think you can do all you want to.
    Essentially, the VRO is an mpeg-2 stream. If it is already on your HDD then you can just rename the file to .mpg. All the programs on the disk are merged into one but you could use VideoRedo to split the programs with no loss of original quality.
  4. Mod Neophyte redwudz's Avatar
    USA
    mnbvc, Do not post the same topic on several forums.
    Please do not cross post, once is enough.
    Continue in: https://forum.videohelp.com/topic349655.html#1838541
    Moderator redwudz
