Hi,
I have converted several wmv files to dvd but when i play it the audio is out of sync. I had the same problem with divx a while ago and apparently the solution was to decompress the audio.
does anyone know where i can get one of these for wmv files?
thanks al
Hi there.
1st of all, what did you use for converting WMVs to DVDs?
These whatdoes anyone know where i can get one of these for wmv files?
You could try DVD Flick. Your problem likely relates to VBR (Variable Bitrate) audio. Many Xvid/Divx files off the net have that problem also. WMV is a proprietary format, so there's not a lot of converters out there. The payware ConvertXToDVD also should handle most WMV files.
BTW, more information about what programs you have tried for the conversion and the settings and steps used would be helpful. Otherwise everyone is just guessing.
And welcome to our forums.
WMV to MP4 conversion problem
By ajitpals in forum Video ConversionReplies: 1Last Post: 2nd Dec 2010, 05:41 -
wmv conversion problem
By uglijimus in forum Video ConversionReplies: 6Last Post: 11th Jan 2009, 13:30 -
WinAVI conversion problem: SWF to WMV
By Omninescience in forum Video ConversionReplies: 2Last Post: 29th Aug 2008, 13:33 -
WMV Conversion to Xvid - Audio Synch Problems Again
By TonyRomo1227 in forum Video ConversionReplies: 10Last Post: 6th Aug 2007, 17:32 -
.wmv to .MP4 conversion problem???
By killz in forum Video ConversionReplies: 3Last Post: 2nd Jul 2007, 15:58
